What is Workstation MFA for LastPass?
    Workstation MFA is a feature that allows LastPass admins to protect their users' workstations with a second layer of security. Once set up, users can log in to their workstations using their Windows or macOS account password, then they can authenticate using the LastPass Authenticator app (or YubiKey via the LastPass Authenticator app) on their mobile device for verification.
    Restriction: Workstation MFA cannot be used simultaneously with federated login (as federated login only supports multifactor authentication at the identity provider level, and Workstation MFA requires multifactor authentication at the LastPass level).
