What version of LastPass am I running, and how do I update?
You can easily check the version of the LastPass browser extension you're running.
Attention: Currently, there are two different extension menu experiences, so instructions may differ depending on your navigational experience. The "new experience" applies to version 4.104.0 and newer for the LastPass browser extension, whereas the "previous experience" refers to version 4.103.0 and earlier.
- Click the LastPass icon
in your browser toolbar.
- In the new extension menu experience, select the Account tab. Otherwise, in the previous experience, select Account Options OR < your username > at the bottom of the menu.
- Select About LastPass.
Results: Installation information (including the version number, date/time the version was built, and whether the binary component is installed) is listed.
What to do next: You can compare your version number with the latest version listed in the
LastPass Release Notes. If desired, you can
download the latest version of LastPass for your device.
