Where is my LastPass vault data stored locally on my computer?
Your LastPass vault data (e.g., URLs, usernames and site passwords, secure notes, form fill items) is stored locally on your computer, and the storage location is dependent on the operating system(s) and web browser(s) you use.
Windows data storage
Web browser | Instructions to locate data |
Chrome | Run %LocalAppData% then go to Google\Chrome\User Data\Default\databases\chrome-extension_hdokiejnpimakedhajhdlcegeplioahd_0 |
Firefox | Navigate to either location:
Edge | Run %LocalAppData% then go to Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe |
Opera | Run %LocalAppData% then go to Opera Software\Opera Stable\Cache |
Mac data storage
Go to ~/Library/Containers/com.lastpass.LastPass/Data/Library/Application Support/LastPass/
If you are unable to locate the Library folder, you may not have the LastPass binary component installed or the Library is hidden. To reveal the Library, do the following:
- Go to .
- Enter ~/Library in the field.
- Navigate to Containers/com.lastpass.LastPass/Data/Library/Application Support/LastPass/
Linux data storage
Chrome | Go to ~/.config/google-chrome/Default/databases/chrome-extension_hdokiejnpimakedhajhdlcegeplioahd_0 |
Firefox | Go to ~/.lastpass |
Opera | Go to ~/.opera/Opera Software/Opera Stable/Cache |
Android data storage
- Default – Go to /data/data/com.lastpass.lpandroid
- Using a Memory Card – Go to /sdcard/lastpass
