Export admin activity event types reports in the new Admin Console
    LastPass admins can create admin activity reports in the new Admin Console that includes various event types, and additional information.
    Tip: You can view all available event types for LastPass Business on the LastPass Business Log Messages page at https://lastpass.com/logmsgdoc.php. Please note that you must be actively logged in with a LastPass Business account in order to view the list.
    Admin activity event types
    • Add Global Equivalent Domain
    • Add Global Never URLs
    • Add Global Only URLs
    • Add policy
    • Add to group
    • Add to shared folder
    • Added user to SAML map
    • Adding user to group
    • Adding user to shared folder
    • Authentication failed
    • Change group pending
    • Change password failed
    • Change password success
    • Create group
    • Create role
    • Created pending user
    • Creating user
    • Deactivated user
    • Deactivating user
    • Delete group
    • Delete policy
    • Delete role
    • Deleted SAML map entry
    • Deleting user
    • Destroy all sessions
    • Disabled
    • Disabled SAML map entry
    • Edit group
    • Edit policy
    • Edit role
    • Employee account created
    • Employee account deleted
    • Employee account disabled
    • Employee account requires activation
    • Employee invited
    • Enable Duo
    • Enable SecurID
    • Enabled SAML map entry
    • Get shared folder data
    • Group addition
    • Group removal
    • Invite all matching
    • Login to Admin Console
    • Make admin
    • master password reset by Super Admin
    • master password reuse
    • Provisioning credential changed
    • Provisioning service added
    • Provisioning service removed
    • Provisioning sync happened
    • Pushing sites to user
    • Re-invite user
    • Reactivated user
    • Reactivating user
    • Remove admin
    • Remove Global Equivalent Domain
    • Remove Global Never URLs
    • Remove Global Only URLs
    • Remove site from user
    • Remove user from company
    • Remove from group
    • Remove from shared folder
    • Removing group
    • Removing user from Enterprise
    • Removing user from group
    • Rename group
    • Reporting
    • Require master password change
    • Reset master password
    • Set user name
    • Sharing key removed
    • Sharing key replaced
    • Sharing key updated
    • Stop requiring master password change
    • Successful authentication
    • Update folder permissions
    • Update policy users
    • Updated SAML map
    • User deprovisioned
    • User provisioned
    • View all matching invitations
