Which Identity Providers are supported for LastPass Federated Login?
LastPass Business accounts can set up federated login using AD FS, Azure AD, Okta, Google Workspace, PingOne, PingFederate, or OneLogin as the Identity Provider.
Restriction: LastPass does not support the use of multiple domains for directory integrations and federated login, including the use of different directory instances and/or multi-domain & multi-forest configurations. Learn more about federated login limitations.
Instructions for admins
- AD FS
- Set Up Simplified Federated Login for LastPass using AD FS
- How do I migrate from using AD FS or PingFederate to a cloud-based federated login identity provider for LastPass?
- How do I convert an existing LastPass user to a federated (AD FS or PingFederate) user?
- Troubleshooting Federated Login for Active Directory Federation Services (AD FS)
- Azure AD
- Okta
- Google Workspace
- PingOne
- PingFederate
- OneLogin
