Why am I not being prompted for multifactor authentication?
If your account is enabled to use multifactor authentication and you are not being prompted to authenticate upon logging in, this is expected behavior if your device is set to trusted or you are accessing the offline version of your LastPass vault (with the exception of the YubiKey authenticator).
To be prompted for multifactor authentication again, you can revoke trust or disable offline access for your device.
