Why do I see "LastPass could not write to your hard drive"?
    Cause: Cause
    You have likely changed the location of your temporary file directory or have set it as read-only.
    Remedy: Remedy
    1. Make sure that you have fully exited all browsers.
    2. Make sure no LastPass process is running in Task Manager
    3. Start a Run command: go to Start menu > Programs > Accessories > Run.
    4. In the Run command that appears, please type: %temp%
    5. This will show you where your temporary folder is located in the top bar. ex: C:\Users\User\AppData\Local\Temp
    6. Note the path and folder here to use in a later step
    7. Open a Command prompt: Run command. Type: cmd
    8. In the command window (black terminal window), type: attrib -r +s drive:\<path>\<foldername> Replacing 'drive:\<path>\<foldername>' with the path that you retrieved from the instructions above (should end with \AppData\Local\Temp)
    9. This should then remove read-only status from your temporary folder and the message should disappear
