Workstation Login stopped sending me authentication prompts, what should I do?
If you are no longer receiving authentication prompts when logging in to your workstation, you will need to re-pair your workstation installation with the LastPass Authenticator app. If you are still having trouble, you will need to re-pair your LastPass account with the LastPass Authenticator app.
Re-pair your installation with the LastPass Authenticator
Re-pair your LastPass account with the LastPass Authenticator
If you have re-paired your workstation installation with the LastPass Authenticator app but are still not receiving an authentication prompt, test authentication for your LastPass account by logging in to the LastPass Authentication portal, as follows:
