Apelido |
The name of the app how it appears in the Admin Console (and Cloud Apps, if your users have a LastPass password management vault) |
Função |
Custom role that you created to organize users and the permissions assigned to them |
Identity Provider (LastPass) |
This is the URL of the identity provider, which is LastPass:https://identity.lastpass.com
Status de retransmissão |
URL to which the service provider redirects the user after processing the SAML response |
Identificador |
These settings will depend on the app you're configuring – please refer to the SSO app's documentation, then select one of the following:
- Email (default)
- Secondary Email
- ID do usuário
- Grupos
- Funções
- Personalizada
SAML signature method |
SHA256 (uses 256-bit hash) |
Assinar e criptografar |
Make your desired selections from the following:
- Assinar asserção
- Criptografar asserção
- Assinar solicitação
- Assinar resposta
Upload partner certificate |
Select the partner certificate you saved locally (if applicable) |
Custom attributes |
To add more custom attributes, select Add SAML attribute and choose from the following options:
- E-mail
- Secondary Email
- ID do usuário
- Grupos
- Funções
- Custom (associated with the SSO app)
