Universal Proxy v4.x exemplo de configuração
O conteúdo do arquivo server.properties deve ser o seguinte:
O preenchimento do campo company.name é opcional durante a configuração. Se não tiver configurado esse campo, ele não constará do arquivo server.properties.
### This configuration file contains the settings for the Universal Proxy.
### It has four sections
### * Server settings
### * LastPass API settings
### * LDAP settings
### * RADIUS settings
### Fill Server settings and LastPass API settings first. Then fill LDAP settings if you plan to use
### Universal Proxy using LDAP or LDAPS or fill RADIUS settings if you are going to use RADIUS.
### If a value is not applicable for your case leave it as it is.
### For further information see the online documentation:
### https://support.lastpass.com/help/what-is-lastpass-universal-proxy
### Note, that it is also possible to configure Universal Proxy using the command line tool.
### Issue the following command in PowerShell to start the command line configuration tool:
### uproxy -configurationTool
### Online documentation for the configuration tool:
### https://support.lastpass.com/help/how-do-i-configure-the-lastpass-universal-proxy-via-command-line
### Universal Proxy Server settings ###
## Server settings: set these values to configure how the Universal Proxy handles incoming authentication
## requests. Choose the authentication protocol (LDAP, LDAPS or RADIUS), specify the ports and domains and
## set the server mode (LP, PLP, SFA).
## For an explanation about server modes see the documentation:
## https://support.lastpass.com/help/what-is-lastpass-universal-proxy#server_modes
# The protocol to authenticate users. [LDAP | LDAPS | RADIUS]
server.protocol=LDAP
# The mode in which Universal Proxy should run [LP | PLP | SFA].
server.mode=SFA
# The port on which Universal Proxy listens on.
server.port=389
# The name of your company. This value appears to end users in the MFA app.
company.name=Test-company
### Authentication server settings: Common Login Service ###
cli.cls.integration.key=your_cls_integration_key_goes_here
cli.cls.integration.secret=your_cls_integration_secret_goes_here
default.cls.auth.method=push
### Authentication server settings: LDAP server ###
## LDAP settings: set these values to configure Universal Proxy to be able to communicate with a LDAP server.
## Leave these values blank if you are not planning to use Universal Proxy for LDAP authentication.
## The ldap.admin.password field is applicable only if the server mode is LP.
## The ldap.address, ldap.port and ldap.tls fields can only be used if the server mode is either PLP or SFA.
## For the current server mode see the value of the server.mode variable in this file.
## Leave any value blank which is not applicable for your current setup.
# The address of the AD. Applies to server modes: [PLP | SFA]
ldap.address=172.19.0.5
# The port on which the AD expects authentication messages (default: LDAP: 389, LDAPS: 636). Applies to server modes: [PLP | SFA]
ldap.port=389
# The distinguished name of the LDAP admin user. Example: CN=admin,CN=Users,DC=domain,DC=com
ldap.admin=CN=testAdmin,CN=Users,DC=testproxy,DC=com
# The password of the LDAP admin user. Applies to server modes: [LP] only.
ldap.admin.password=your_password
# LDAP naming attribute: the name of the LDAP field in which the Windows user logon name is stored. Possible values: [cn | uid | userPrincipalName | sAMAccountName]
# ldap.attribute.login=sAMAccountName
Verifique o seguinte:
- O valor do campo ldap.admin deve ser igual ao valor do campo distinguishedName do Active Directory.
- O tamanho máximo dos sAMAccountName é de 20 caracteres.
Artigo anterior: Universal Proxy v5.x exemplo de configuração
Próximo artigo: Exemplo de configuração do Universal Proxy V3.x
