Topic
Field Fills Not Working Properly
Skip Feed
Matt73160 (Customer) asked a question.
How do I manually edit form field names, add new fields to a form?
In order to get a form on my banking app to fill all of​ the fields that need to be entered, I believe I'll need to edit the form field names or add new fields to be filled. I saw online it mentioned a Form Field Editor, but I don't see anything like that in the app and I can't get onto the website with my phone because it says is have to do a device switch to computer (even while accessing it with my phone), and I don't want to switch just to see if it might be available there.
How​ can I use the Form Field Editor?
Or has this feature been permanently removed? If so, why?
If​ I can't use the editor, how can I get my bank login page to fill correctly? It's BancFirst, if that helps.
Matt73160 likes this.
End of Feed
1 Items
Details
Topic Details
Name
Description
